Look for the Uclan it works out cheaper but waiting on stock at the moment.
I'll do that. Thanks
Code:http://uclan.tv/ustym-4k-pro/
Could be a good investment from what I saw on their website. Their website is a bit lacking on information, like Demodulation (QPSK,8PSK,16APSK,32APSK), and whether or not it will come with a USA wall wart. It makes it nice when all the specifications are listed on the website. I assume you got a price?
https://www.world-of-satellite.co.uk/
Yes there web page is not very informative use information from the Octagon 8008 its the same unit, including shipping my Uclan worked out at £92 pre-order ,
This seller is the cheapest in uk for the Octagon they are awaiting stock, they work out at £109
Code:https://www.world-of-satellite.co.uk/
https://www.opena.tv/octagon-sf8008-4k-uhd/42134-neue-octagon-hisilicon-sf8008-4k-uhd-ankuendigung.html
Keep a eye on this thread from what i can see bugs are getting fixed asap, i personally take no notice of signal strengths it locks a weak signal or it doesn't, the tbs 5925 is one of the more expensive units i own and its rubbish for fringe reception the cheap Freesat V7 £20 walks all over it.
Code:https://www.opena.tv/octagon-sf8008-4k-uhd/42134-neue-octagon-hisilicon-sf8008-4k-uhd-ankuendigung.html
Thanks![]()
Can you share the information on the store you purchased the Uclan receiver
https://www.satmarket.com.ua/dir_resiveri_ultrahd.htm
Thanks Martin, the price for it is 45.10 dollars, I am not sure if this is the same receiver, I try to e-mail but I don't understand the language.
Regards.
Tunder
Hi Tunder shipping bumped the price up, you have enough references to check your looking at the right box in the links ive posted in this thread, i also don't speak speak any Russian you will have to use google translate, good luck please let us know how you get on.
Google Translate
kdjuan, did you ever get your d4s to work, just got one tokay and getting " format not supported " on tv screen, maybe trying to do pal format not ntsc, anyone know how to changs, ??? thanks
Limited time offer
