DN500 Installation/Location Question | SatelliteGuys.US
mstrcln
3
Can I install my dish on the pipe coming out of my roof carrying the power line to the fuse box? Perfect location on my roof. Will there be any EMF trouble?
Thanks, Bob:(
Seriously, don't attempt this! Those power wires are not protected by your panel's 200 amp breakers. You accidentally touch those and you can get in excess of 50,000 amps through your body.
Thanks for the response! They way it is situated... I would have to try very hard to get into the wires.
Alright. How about, it's a violation of code and the power company can disconnect your power at the pole if they feel the dish is a hazard. They probably will. Reconnection at the pole is pretty expensive as it has to be done live.
Ok, Ok, I get it. I was mostly worried about the interference as I am moving the dish closer to the TV. I don't have a problem mounting on the roof, but need to find proper pole mount. Was on TV tower.
Dish Quality
New Dish Cust. East Arc Questions.
