H herzzreh SatelliteGuys Family Original poster Aug 2, 2005 61 0 Aug 3, 2005 #1 Quick question... can the DP21 switch be used with non-Dishnet LNBs?
K kavula SatelliteGuys Pro May 30, 2005 217 0 Aug 3, 2005 #2 Not in general. I'm not aware of any non-E* LNBs that are DishPro. It's all or nothing; if you have a DP switch, you have to have DP LNBs.
H herzzreh SatelliteGuys Family Original poster Aug 2, 2005 61 0 Aug 3, 2005 #3 kavula said: Not in general. I'm not aware of any non-E* LNBs that are DishPro. It's all or nothing; if you have a DP switch, you have to have DP LNBs. Click to expand... OK... Any other options on connecting 4 outputs (2 from 110 and 2 from 119) to a dual-tuner receiver? Due to my location I can't get a regular Dish antenna so I have to improvise...
B BobaBird SatelliteGuys Pro Sep 8, 2003 1,693 0 EKB Annex Aug 3, 2005 #4 2 SW21 switches. If you need to connect more than 2 tuners get an SW44 for 2 sats or an SW64 for 3 sats.
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Aug 3, 2005 #5 Microyal is supposed to be making DP compatible LNBFs but I haven't seen any distributers selling them.
H herzzreh SatelliteGuys Family Original poster Aug 2, 2005 61 0 Aug 3, 2005 #6 BobaBird said: 2 SW21 switches. If you need to connect more than 2 tuners get an SW44 for 2 sats or an SW64 for 3 sats. Click to expand... So the SW21 switch will work with Dish 625 and non-Dishnet LNBs?
dfergie Proud Staff Member Staff member HERE TO HELP YOU! Sep 8, 2003 105,516 10,108 West of the Pecos, between White City and Roswell Aug 3, 2005 #7 do a switch check with nothing hooked to first...
B BobaBird SatelliteGuys Pro Sep 8, 2003 1,693 0 EKB Annex Aug 4, 2005 #8 herzzreh said: So the SW21 switch will work with Dish 625 and non-Dishnet LNBs? Click to expand... As long as it's a non-stacked dual-output DBS LNB such as used in a DirecTV single satellite setup.
