DSR505 video blinks | SatelliteGuys.US
DSR505 video blinks
alexcast
32
Mexico city
Hello,
I got a DSR505 Shaw Direct receiver and i'm using a DVI to HDMI Cable
While i'm using it, it started to blink from video to black screen and then video again, on and on each 2 seconds
Do you know how can i fix this problem?
Cheers
This happens with my 505 also and in particular when I switch video sources between my computer to my 505 on my monitor.
If you pull down the little door on the right of the 505 and then just touch the button, it seems to reset the video to the proper setting and it stops blinking.
Thank you keithb
When i touch that button it give me 1080p, 780p and 480p also 00 00 that set the receiver into SD so i will give it a try thank you so much
