the hs17 is a strange form factor, for me persoanlly there is no place it would fit, other than the floor behind the tv stand where the cat would play with itThat is easily solvable with an HS17 and C61K.
It's a server. It can quite literally be put anywhere you can run the coax to. It does not need to be anywhere near the TV.the hs17 is a strange form factor, for me persoanlly there is no place it would fit, other than the floor behind the tv stand where the cat would play with it
well my coax goes from my dish, underground, under the house, outside along the house(tv room is a slab on grade), through the wall to the tv. so can it go outside or under the house? if not its on the floor behind the tv. again the form sucks.It's a server. It can quite literally be put anywhere you can run the coax to. It does not need to be anywhere near the TV.
Why would the coax be under the home and not in a conduit? Id say your home wiring form is far more of a problem. What happens when that coax gives out?well my coax goes from my dish, underground, under the house, outside along the house(tv room is a slab on grade), through the wall to the tv. so can it go outside or under the house? if not its on the floor behind the tv. again the form sucks.
Add a splitter and run the coax to another room or does your house only have one room?well my coax goes from my dish, underground, under the house, outside along the house(tv room is a slab on grade), through the wall to the tv. so can it go outside or under the house? if not its on the floor behind the tv. again the form sucks.
This is an Osprey box with a slightly different primary app that connects to the Genie 2 and acts as a 4K satellite client. Gives the ability to download apps from the Google Play store and better meets the needs of most viewers - desiring one main box for satellite/cable and apps. This is probably a win for most customers.
yes gooDoesn't Google TV require a quad core processor and a couple gigs of ram to run fast? If they put Google TV on the HR-54 it would probably run really slow. It can barely run the APPS it has now.
ours is wall mounted in the media room closet outta sight outta mindthe hs17 is a strange form factor, for me persoanlly there is no place it would fit, other than the floor behind the tv stand where the cat would play with it
The Osprey for Satellite comes with a Ethernet to coax adapterOk so why not just create a Google TV app that acts as a Genie client. I mean the DirecTV Stream app works pretty good, but it doesn’t show ALL the channels or view recordings right off the DVR.
Osprey doesn’t have a coax port does it? So it’s all IP via Ethernet or WiFi to genie anyway right? So a google tv app (or any platform for that matter- Samsung Tizen, Roku, LG WebOS) should work if it’s on the same network as your DVR. Why invest in all this hardware when so many TV’s have enough processing power to do the heavy lifting? Ok sure you can’t control the remote. Maybe that’s part of branding… oh well.
And for those rural areas with no internet options… why not look into Starlink maybe?
What about running the deca adapter to a streaming device? That's how they did it before with RVU? Maybe this time the APP would be a lot better than RVU?The Osprey for Satellite comes with a Ethernet to coax adapter
i called and asked about it. they told me that i qualify to upgrade. and they have my number in there database iv'e gotten calls at 8:30 PST wanting to get me upgraded. i just tell em i'm fine with the clients and that i don't want another contract unless we moved!!! then i told the rep when they came out with something that's worth talking about then maybe just maybe.It allows streaming IN ADDITION to satellite. That said, I called and for some reason I was not eligible. Not that important to me.
you can also use DECA coax to ethernet to connect it also. it would be interesting to see the guide!!! and it would be interesting to see if it act's like the hopper hey google tune to channel xxxx rewind one minute turn the lights down ect ectit was invitation only for HS-17 accounts. as the "box" is a Wireless 4k mini and the Hs-17 has a built-in wireless bridge. allowing the "box' to be a mini and app combo meaning it will access the hs-17 playlist as well as setup recordings.
So, the hell with the rest of the subs ?it was invitation only for HS-17 accounts. as the "box" is a Wireless 4k mini and the Hs-17 has a built-in wireless bridge. allowing the "box' to be a mini and app combo meaning it will access the hs-17 playlist as well as setup recordings.
It’s literally the same interface as a regular mini.you can also use DECA coax to ethernet to connect it also. it would be interesting to see the guide!!! and it would be interesting to see if it act's like the hopper hey google tune to channel xxxx rewind one minute turn the lights down ect ect
Well, those (myself) Included with a hr54 --are free to add an external wireless bridge. to any genie --the only reason would be if you wanted or needed a wireless 4k mini --Should anyone have a location they could not get a wire to.So, the hell with the rest of the subs ?
How about those with the Genie HR54 or HR44.
I will never go the "Server" route, it limits what I can do with my set ups.
I chatted with a DTV supervisor not sure how reliable they are with info compared with CSRs, but he said they are still working out bugs with the Gemini connecting to the HR-54/44.So, the hell with the rest of the subs ?
Agree then there's no sense in upgrading. The only reason I see to upgrade is to download a VPN to watch blacked out gamesIt’s literally the same interface as a regular mini.
The Osprey does the same thing with DIRECTV streamI wonder if it would run faster than the current Mini's because of it having a quad core processor and 2 gigs of ram? Sometimes my c61k's guide doesn't display any info. Then I have to exit out of it the go back into it and it works. Also the guide scrolls a little slow.
Limited time offer
