DTVPAL DVR | SatelliteGuys.US
DTVPAL DVR
This question needs to be moved to the appropriate forum. The forum of choice would be the Digital Over The Air (OTA) forum.
Generally speaking, you set two timers and the DVR records two programs.
Hello, Please if I could ask for your help, we just purchased the DTVPAL DVR, we love it but Cannot figure out how to record 2 programs running at the same time on different channels.
Maybe you should try it. It can be very difficult to debug something like this with an intermediary.
I like using timers because it usually gives you a warning when you're trying to do something that can't be done for some reason.
Has there been any attempt to read the documentation?
Yea, try it yourself. I record two shows at the same time about 3 times a week with no issues. I normaly do what Smitty says, set to record in the guide. Then if I want to change a timer to weekly I just go into the timer menu and edit it. This box has been great since they upgraded the firmware months ago.
I just went to the guide and clicked on 2 shows and it recorded them both. I hope you have better luck with yours. Ours didn't last long. :(
ota antenna help
Best PVR?
