dvb card recommendation for HD on 87w | SatelliteGuys.US
bin44
23
I just bought a Dell E521 (7300LE as the video card; AMD Athlon™ 64 X2 Dual-Core 3800+ as the processor and 1 GB memory). I want to get PBS HD on 87w for my son. What dvb card would you guys recommend? I'm thinking about twinhan 1025 and found one for only $35 without a remote. Should I get a 102g or 1027? Is the video card good enough for HDTV?
Just about any DVB card will work. The twinhans are pretty good as they work well with TSReader, DVBDream, MyTheater, and many other DVB apps.
Your system should run the PBS HD feed fine as long as you've got the line of sight and dish to see it.
Thank you very much for the reply, digi. I guess I'll buy one twinhan 1025. I'm sure I'll come back when I have all my parts
HH90 lying all the way West
Universal code for Microyal 1200 Remote Control
