The name of the new software you downloaded and you are trying to install is:
"V2.0build02_20100512 DVB World"
Right?
yeah but when I try to install even though I supposedly uninstalled the previous version, installation program tells me the "drivers" already exist, so then I select "force to install drivers" and same old same old, when I open DVBWorld.exe, its the old version yet again.
This really is stomping me, either the driver pack i've installed is not the one for my model or I need to completely delete any old driver and files from the registry, even though I have uninstalled this thing like 5 times![]()
you need to uninstall the drivers using device manager, uninstall the software with control panel, then reboot, then install the new software. works great. scan times seem to be 12 minutes or less for me. pretty thorough as well. thanks dvb world.
crackt out,.
When I go to the about page I see: DVB World 3.1 B01 9-30-2009
Do you have the DVB World receiver with the Conditional Access Module / Smartcard Reader ?
If you are getting the "09-29-09" I hope that you are having a software/driver problem (I hope you have the correct device, as your receipt shows that you did purchase the "D" version)
Here are pictures of the "C" version and the "D" version:
2104D (Blind Scan Version)
2104C
It seems to scan each polarity three times (you can not change this).
You can not select a symbol rate range to scan, but you can select the frequency range to scan.
EDIT: Do you remember how I have said that you can enter an approximate symbol rate and lock a transponder, were/are you able to do that?
Example for a transponder with a symbol rate around 30000 can you lock it by entering 20000 ?
Nope I wasn't able to do it, to lock it had to be close to the real SR
This seems odd to me, why would it scan several times, it wouldn't make sense to scan at a faster rate once you already scanned at a slower one, you would'n't pick up any more signals at a faster scan rate. Maybe it just scans three times at the same speed for thoroughness? The scan times are not impresssive, the skystar 2.3 I had would do blazing fast satellite scans, a matter of seconds not minutes, granted it was only dvb-s no s2 but still...
Limited time offer
