DVR Firmware 3.20 Released on 6/30/2009? | SatelliteGuys.US
v3.20 was not yet released as we are implementing a change before release.
If you desire to know what firmware or channel list is currently available via satellite OTA update stream, select OTA, Update Now. If you do not wish to update after reviewing the firmware information, press Exit.
My DVR updated without asking permission, but I like it that way.
I have experienced an anomaly since the update, but it may be unrelated.
I had a freeze on 7/22 when using start record, I couldn't stop it after one hour and had to turn off via the rear panel. I didn't reset the time and failed to check the time when setting a timer on 7/23. Because of a coincidence the factory default time started my program an hour early. On playback I noticed the USB date was incorrect and that time was still counting from the factory default. I went to time adjust screen and it was on auto. I then did a manual adjust and reselected auto.
Lip Synch Problem - Resolved
Firmware update for Fortec Mercury II
