E-8 on 119 ok, but E-6 not | SatelliteGuys.US
Ebro
4
I have a 321 on 110. I do recieve channels on the Echostar 8 Satellite ok. But the ones on E-6 I don´t. I get the message that the signal has been lost. Any ideas? Thanks :confused:
Iceberg said:
E8 is on 110...E7 is 119 :)
E8 does 5 spot transponders (reused all over the US) and 16 conus transponders. It covers 21 of the 29 transponders Dish has at 110, E6 covers the other 8. E7 does 5 spot and 16 conus or 21 transponders, the total that Dish has at 119. E5 sits turned off at 119 for a backup.
In south TX you should have no problems. It is only those outside the US that have problems with E6. Perhaps you have a dish out of alignment, a bad LNB, bad wiring or a bad reciever... A lot of possibilities, could be easier just to call Dish.
