FYI to the AK and HI subs, several HD channels will be moving from 110 spots to 119 and 129 spots on 5/27 and 6/02
Receiver: (DVR 625)
Area: Bayamon, PR 00956
Weather: Cloudy
Dish: 2 (1 4', 1 3')
Time/Date: 12:40 pm/5/22/2010
TP 1: 0
TP 2: 125
TP 3: 0
TP 4: 0
TP 5: 0
TP 6: 125
TP 7: 0
TP 8: 73
TP 9: 77
TP 10: 125
TP 11: 80
TP 12: 82
TP 13: 125
TP 14: 125
TP 15: 89
TP 16: 78
TP 17: 125
TP 18: 125
TP 19: 86
TP 20: 76
TP 21: 125
History Channel is coming with heavy pixellation. :-(
Updated the first post with E14 loading information
I assume that the spot beams for transponders above 5, are there to be used when Western Arc shifts to 8PSK ?
I also assume that EchoStar 7 is now turned off ?
PS So now, over a period of four years, Dish has replaced all the satellites on Western Arc...
Interesting they have moved from 24 to 40 spot beams being used. Very nice increase in local market coverage ability. It also looks like they could hold a lot of backup coverage if they had failures at 110 they had to cover.
On 6/10 a couple of CONUS TP's will move from 5/6 FEC to 7/8, the rest of them on 6/17 will change to 7/8 FEC.
Digiblur, Is there any way you can tell us what TP numbers are changing FEC on 6/10? Can you also tell what time? 3am Eastern? Thanks.
ok here's what I have done to try to get 119 in Northern Alberta Canada
I had it 119 before the switch was getting very good signal on Tp 11 around 90%
then nothing tried to re point it with no luck tried DP 301 DP 3700 DP 6141 d box fta
I can pick up 110 easy and 91,82, 129 no problem. but 119 is hard I'm using sat buddy finder. using 1.2 meter dish and legacy LNBF.
I tried Transponder 6 no luck
what are my options and what transponders should i use.
thank you for all your help in advance.
been with out my shows since it went down for me. other than 110 it's good.
When will the transition of 119 be over, if you know?
Finnigan
Limited time offer
