EF ECOFLOW Portable Power Station Delta 2, 1024Wh | Page 2 | SatelliteGuys.US
That could be the reason. Follow the coax back to the dish, and see what it all goes through. IF there's a powered switch, that'll also need to be on a UPS. That might fix you up.
The cable from the Dish on my roof comes down to a Hybrid Solo Hub and then it goes into the house. There is nothing after that.
Reactions: charlesrshell
I would check the voltage actually being fed to the hopper. If it's too low it can cause the hopper to not send power to the lnb which would result in no signal. Also if there's any grounding on the solo hub or dish, it can also cause issues if theres other electrical issues.
