EHD/DVR Expander | SatelliteGuys.US
EHD/DVR Expander
jhaan79
17
5
Pontiac, IL
Hey everyone! I am at the point where I need more storage for my shows. I ordered a WD MyBook DVR Expander about a month ago from a site, found out it was on order, and now the website says it has been discontinued. So I think I am back to square one again. I don't pretend to be an expert on this so I figured I would reach out to you guys. The links at Dish Network for EHD go nowhere and I am wanting something for a reasonable price. The whole DVR Expander/EHD thing has me uneasy 'cause from the looks of it whenever I search for a product, it includes EHD storage for computers. I need a DVR Expander correct? Thanks for your guys' help!
A computer EHD works just fine as long as it is self powered.... I use a WD Elements and it has has been flawless for years.
I just slap bare drives into a couple of USB docks.
KAB, I tried that with a 1TB Purple drive that I already had on hand in two different enclosures and had absolutely no luck with it. Then found a really good deal on a 2TB unpowered drive and bought a powered hub and have been very pleased.
Define, no luck with it.
No luck means the Hopper never acknowledged that I had connected anything. I had one device that had no enclosure, but had a power supply and ports for SATA, IDE, and 2.5" IDE that would work intermittently, but never reliably. My 2TB WD Elements unpowered drive along with the powered hub has never missed a beat. Maybe I just had bad luck when choosing enclosures, but they all worked with my desktop.
Just got the 2 TB WD Elements in the mail today. Just wondering how long it takes to format the drive (a.k.a. how long the 'Attention 869' box will be on the screen). Thanks all who have commented so far!
Shouldnt be any more than 45 minutes. Larger the drive, the longer it takes. Also, I have heard but cannot confirm, the more stuff on the Hopper will actually slow down the formatting process. So simply put, it can be anywhere from 5 minutes to 45 minutes. Anything longer, reset both the receiver and hard drive
Well, you were a little vague on the specifics. EHDs are generally used at home as an extension/offload of the main receiver. You never mentioned taligating.
Reactions: Tampa8
I saw a report months ago that the software partition allocations should work with a 3TB but not 4TB. (I can see where that might be true.) Dish software may restrict it, even so. Has anyone here made a 3TB work or found a Mac workaround to make dish software accept one? I'm looking to get price to $30/TB. I got a 2TB for $60 on first sale of model and works great but now at $40/TB or more.
-Ken
I'd rather have more disks to minimize losses, but most especially to actually SEE all items listed, not just the first 1,000
If most of what you have are movies then it is likely the 1000 limit would not be a problem especially as the limit is likely in excess of 1500 titles. The 3TB limit would be from the size of one of the tables, so is less likely to be bypassed. Losing files to crashes etc., will not be more likely with smaller drives, just that when (not if) it goes down the loss is bigger at that time but still painful either way.
Showing more than the first bunch varies with time of day and needs a DISH fix. -Ken
western arc 1000.2
Al Jazeera America HD now live
