Elecard - Accessing Deinterlace Settings | SatelliteGuys.US
nhulst
SatelliteGuys Guru
138
2
After a couple of years of TSReader + VLC, I'm branching out and trying to see if there's anything I like better. I have both ProgDVB and an evaluation copy of DVBDream installed, and I'm using the latest Elecard codec. However, I can't figure out how to manipulate Elecard's deinterlace settings. Elecard has a "filter configurator" utility on its website, but the DVB apps don't respond to it, even after restarting. I can't find any menus in either of the apps that allow control over Elecard's settings directly. Can anyone help?
From memory, I think in ProgDVB just click properties and then the different codecs for the settings if there is any. It's probably specific to each player you use them in.
In DVBDream, codec settings/info can be accessed using "Options"-"Video" . Then double-clock on the codec name in the "Active DirectShow Filters" panel on that page.
DRCars
DRCars
This worked perfectly--thanks! Still no luck with ProgDVB, though. Too bad, because I prefer that software otherwise, but it's not usable if I can't turn on deinterlacing.
I'm using the lastest version of ProgDVB Pro. File/Properties/Filters. Select the filter (codec) you want to modify.
i had been looking in completely the wrong place. Thanks!
Unfortunately, regardless of which app I run, it crashes when I change a setting in Elecard. :( Time for a reformat...
neusat I pro 2000 plus
Univision gone on 4167V - Galaxy 3, 95.0W?
