I think a septum feed for C-Band circular would be better than a dielectric plate insert. Might be enough to bring in 53W.... I reused the C1W-PLL side-mounted to the scalar of the C2-PLL, with the dielectric plate, and use it successfully on 34.5W, 40.5W and 47.5W. (Not much luck with 53W but that one is tough here even with a properly centered LNBF)...
what does that look like? Is it a tube with some flat areas on the inside, facing each other? I see something like that in the circular Ku feed of the DN SuperdishI think a septum feed for C-Band circular would be better than a dielectric plate insert. Might be enough to bring in 53W.
I know they make septum feeds for KU band, but have not seen one for C band.
ah ok, thanks for the explanation! I have seen that inside DN LNBFsA septum is a stair-stepped piece of metal. There are probes on both sides - one for RHCP and one for LHCP. Posts 9 and 10 in the following thread show a septum I made for L-Band: Experimenting with L-Band antennas
From my experience, septums work better inside a square waveguide vs. cylindrical. The easiest way to make one for C-Band would be to remove the cylindrical tube from an existing C LNBF and put the probe inside a homemade septum feed.
Limited time offer
