pjcl SatelliteGuys Pro Original poster Nov 9, 2008 318 0 Earth Nov 6, 2011 #1 I just hooked up an Openbox S10, and I'm fairly happy with it. Now, can anyone tell me what I can do with the Ethernet port it comes with? Thanks!
T the_man_one SatelliteGuys Pro Dec 22, 2006 228 2 Nov 6, 2011 #2 you can look at it...... isnt it pretty?..... now if u were in europe u could do things that arent talked about
KE4EST SatelliteGuys Is My Second Home Staff member HERE TO HELP YOU! Lifetime Supporter Aug 9, 2004 27,035 7,363 EM75xb Nov 6, 2011 #3 Yeah its not good for anything in this part of the world.
S Santa Clause SatelliteGuys Pro Oct 30, 2007 211 11 Coastal Maine Nov 6, 2011 #4 This has been discussed in an earlier thread http://www.satelliteguys.us/free-air-fta-discussion/263735-openbox-ethernet.html. Would be a good alternative for some to update firmware. Has anyone tried it?
Jim S. When someone asks you if you're a god, you say yes Lifetime Supporter Jan 2, 2006 5,795 1,541 FN11od Nov 6, 2011 #5 I've tried it. In some versions of the firmware it works fine, other times it crashes the box. I haven't had any problem uploading and downloading channel lists with it so far, but I haven't used it too much.
S Santa Clause SatelliteGuys Pro Oct 30, 2007 211 11 Coastal Maine Nov 6, 2011 #6 Do you use the same loader that the RS232 connection uses?
Jim S. When someone asks you if you're a god, you say yes Lifetime Supporter Jan 2, 2006 5,795 1,541 FN11od Nov 6, 2011 #7 No. The program is called STBHD_LAN_MM. I don't remember whether it's been uploaded here.
