I want to know how to transfer the contents of my 1.5TB and 2TB drives onto new drives.
WHY???
So I removed it and attached to my Linux box. What I see is unexpected. It appears to have created 1 1.1GB and 5 537GB partitions, with a DiskArc folder in each 537GB partition.
I want greater capacity than I currently have and since any recordings I transferring back to the hopper end up corrupt, my only recourse I can come up with is to transfer them from the old drives to the new ones manually.WHY???
Disk manufacturers use powers of 1000 because it looks bigger.
Computer people use powers of 1024. Both are correct in their way.
Thus DM 1 TB drive is 1000^4 = .909 TB by our counting.
A 1GB DM drive would be 1000^3 = .931 GB by our use.
Does this account for your difference?
-Ken
-Ken
I believe he was addressing Krell and his "missing" 135GB comment.Not sure if you are addressing me. My point about 2793GB was to show that the Hopper does support more than 2TB external drives.
I know all about marketing vs "true" space...![]()
So, you take your TWO separate drives, then combine them into ONE and then the ONE goes bad...what have you got? This is a situation where bigger is not better.I want greater capacity than I currently have and since any recordings I transferring back to the hopper end up corrupt, my only recourse I can come up with is to transfer them from the old drives to the new ones manually.
Hopper files size are in 1024^3 * 3-digit decimal fraction on the Edit screen's GB.
Thus they are numerically smaller than expected on 722, which used 1000^2 * integer MB.
I have to account for this in my 3000+100s of entries spreadsheet with change of hardware. It makes it difficult to compare Futurama sizes--always looking for the smallest complete show.
The nice thing on the Hopper is you can read the size without requiring an EHD loaded.
I wish that I could get a list of sizes and not just one at a time. Just so much on a line.
The displayed available size is for Hopper's destination instead of always for the internal. Good.
-Ken
Not combining, just increasing capacity of both. Going from 1.5 & 2TB to 2 3TB drives.So, you take your TWO separate drives, then combine them into ONE and then the ONE goes bad...what have you got? This is a situation where bigger is not better.
Dealing with more drives that can be attached at one time gets too complicated. For me, I could deal with it, but for the family, how do you create a process of switching between drives? Is that something you want to expose the family too? Not me. I've tried a USB switch, but it still created too much complexity for the others. Having something always attached and accessible reduces things to simply navigating the hopper menus.You have to weight convenience (a single drive) vs. inconvenience (multiple drives). Either way, if a drive fails you lose content. Nothing around that, unless you were to start buying devices that mirror internally which lowers your likelihood of an impacting hardware failure. Most people, including me for that matter, don't think too deeply on this subject for home use.
The quickest thing to do would be to let the receiver format the new 3TB drives, then use a Linux boot CD on your computer to copy the Disharc folder and files from the old HDDs to the new ones. Done.
So are you saying I can do everything, the hopper is doing to format the drive, on my desktop myself? I tend to agree with you, but other than the partition sizes and the filesystem used, what other things must I manually do to ensure compatibility?Our use a *nix based OS as your desktop and you're already booted. Besides all the variants of Linux there is also Mac OS. Cheers
Easier said than done. The format on the hopper runs forever (never completes) on this drive. Unplug and replug restarts the entire process. This is my reason I'm looking for alternatives methods to initialize.Let the Hopper Format it, then disconnect it. Move your data. That's it. The files are encrypted, the file system is not. You might also try this (caveat: I have not) -- a freeware tool for ext2/ext3 for windows: http://www.ext2fsd.com/
Limited time offer
