Will do......thanks againJust remember. Do not hook up the ehd till after the new receiver is fully authorized and up and running.
Thank youWhen you get the message to reformat the drive DO NOT ANSWER YES. What you need to do is first unplug the receiver then when it has rebooted itself plug in the EHD and power it up. You will be fine and will see everything you had stored on the drive.
harshness said:The secret to success may lie in not paying attention to outdated documentation.
If the DVR throws a message about wanting to format, tell it no and contact DISH Network about your issue. Chances are awfully good that it WILL NOT offer to reformat.
No. IIRC, the 625 does not have USB2.0, only 1.0. Thus an order of magnitude slower. And no software either for an EHD.
-Ken
I also just noticed that on the Dish site it says the maximum EHD is 2 TB but the Dish dude said only 1 TB......so which is correct?
2TB is max
The first stop will hold the show. A second stop will bring it to the selection menu for resume, start over, or done.
-Ken
I wish they had a delete in that menu, so I don't have to go back through the list to re-select and delete.
I wish they allowed rewind from the end, like they do on the internal. A real pain to search near the end this way.
-Ken
So does anyone have any clues as to why I can't delete anything from my EHD? I will be calling Dish tomorrow but it seems some of them don't know to muchHey guys just an update....I got my replacement 622 and it works great and I hooked up my EHD but when I try to erase a show from the EHD(archive) it's still there.I tried to restore a show back to the DVR and then delete it and it does delete it from the DVR but it's still there on the EHD..What's up with that? Also one more question.....when watching a show on the EHD and I hit stop it just shows a still picture and not the screen with all the options such as resume....delete,etc.
GaryZ06 said:So does anyone have any clues as to why I can't delete anything from my EHD? I will be calling Dish tomorrow but it seems some of them don't know to much
Just wanted to let everyone know that we were able to get it working. I had to send an authorization signal and then GaryZ06 did a hard rest on both the EHD and 622. Just wanted to share in-case anyone else runs into this problem.
Limited time offer
