External HD results: Drives Working Properly | Page 3 | SatelliteGuys.US
Ok, I have the following "make your own" arrangement.
A Seagate ST3750640A 750GB PATA HD in a Galaxy Metal Gear 3507UC-Silver External Drive Enclosure (w/fan).
--Doug
Did I not read somewhere that you can't have 2 usb items hooked to the VIP at once? I think I will run a usb cable from my pc to the VIP Fan.
can't have 2 usb hard drives at the same time.
I have my thermalTake fan plugged in the back and the EHD plugged in the front.
If you're going to do this why didn't you stick with the Seagate? It works flawlessly if you power it off when not in use.
Only until it spins down again. Then you need to turn it off/on again. With the SimplTech just need to start it up once when you power up your receiver. If I plug it into the Audio Receiver I will not have to worry about spin down problems of the Seagate
WD Mybook 320gb 8mb buffer
Works fine EXCEPT:
If you do alot of FF, Advance when viewing an archived show.. there is some stuttering when play resumes. Sometimes you even have to FF a few sec, then play again to get it to stop.
Works fine on just Play.
Works fine EXCEPT:
Could be 8mb vs 16mb buffer? No such symptom on my 16mb.
Does Dish Online work yet?
VIP 622 Question
