I want to get a Universal LNB so I can get extra channels that use R,L
I originally bought this:
Chaparral C/KU band Corotor ll Plus Combo Pack, Feedhorn w C and KU LNBs
The Corotor II Plus is designed for systems which require reception of both C and Ku-band signals. The Corotor II Plus is primarily for reception of satellites in the United States.
Corotor 2 Plus Features:
Patented probe for C-band reception
Unique Low-loss dipole antenna for Ku-band reception
Receives linear C-band signals in the 3.7-4.2 GHz Range
Receives linear Ku-band signals in the 11.7-12.7 GHz range
Built in the Chaparral tradition of quality, the Corotor II Plus is the ideal choice for systems which require reliable performance.
My question before I just thru my money away is:
Can I just replace the regular Ku LNB for a universal Ku LNB without changing the other parts: Scalar Ring and Feedhorn? Or will I need a special Feedhorn that will support the universal KU lnb. I also want to continue using the C band setup.
Thanks for your help.
