The AI Turbo S2 is a great tool. But it takes some doing to learn it's functions and what they mean to you. Do take the time to peruse the menus and locate the different settings. Hook it to a dish that works good so you can see some expected results. It was not "Plug and Play" for me at all. It took awhile to figure it all out. But I know you can do it. I saw you program that KPT966
Yeah, I wiped it clean to factory defaults which left it with the same capabilities as a raw potato.
I went through and made a list of all the satellites that I might possibly ever take a look at.
Then I came up with a naming convention because it requires separate entries for KU and C band.
I wanted them all in order as well.
So in the meter I designated them by position, then name, then band type.
72 AMC-6 KU
83 AMC-9 KU
87 SES-2 C
87 SES-2 KU
89 G28 C
89 G28 KU
91 G17 C
91 G17 KU
95 G3C C
95 G3C KU
97 G19 C
97 G19 KU
99 G16 C
101 SES-1 C
101 SES-1 KU
103 AMC-1 C
103 AMC-1 KU
105 AMC-18 C
107.3 AF1R C
107.3 AF1R KU
111.1 AF2 C
111.1 AF2 KU
121 G23 C
121 G23 KU
123 G18 KU
125 AMC-21 KU
After I created all the names I had to program each satellite entry for the proper LO for C or KU.
Then I had to manually enter each and every transponder and frequency, one at a time according to the sathint page which seems to be a bit dated in places.
I HATE blind scanning with this thing because if I'm on the wrong satellite (it does not ID) then it fills the thing up with rubbish.
If I think I'm on 101 C but I'm really on 99 and I blind scan, it fills up the 101 entry with wrong stuff and it's a PAIN to clean it up.
I really hate this stupid little meter. It's just soooo mickey mouse. Not to mention, it's 100% incapable of recognizing S2. And it is also 100% incapable of doing pay stuff like Dish and Direct. Not that I care about Direct but since I am a paying Dish subscriber I would LOVE to tweak my Dish dishes too.
In it's day this little meter was OK but a lot has changed since then.
Oh, and then there's the problem with the tiny little screen. You can NOT see it in sunlight, period.
There are no brightness or contrast adjustments on it at all. In daylight it's utterly useless.
As for the Birdog, I tried to program it but you have to use their clunky, ancient website utility.
It only has 16 slots. Actually it has 32 but if you put an entry for each polarity then it's 16.
And even worse, for instance, the SES birds, it takes FOUR entries for each satellite to cover C and KU.
For the two birds I have to use eight slots in the memory.
And what's more, I have no clue if their configurations you download from them are current.
It does not tell you if you're downloading something that's 10 years old or 10 minutes old.
And we all know how they love to change stuff up on satellites, frequently.
And of course it does not do S2 at all.
Some years ago I requested a copy of the software for creating your own lists from scratch but I found it to be confusing and obtuse. I never had any real luck creating my own lists with their software.
The little KPT meter can not connect to a computer. You can't upload/download/upgrade it at all. You can't edit lists outside of the meter. You're 100% locked into it's own little world with it's tiny little matchbook screen and joy(less)stick.
Both of those meters are from a bygone era and are stuck in yesteryear for the rest of their little lives.
Once I get the AI Turbo S2 I think I'll put these meters up for sale in the SGUS classifieds section. Hopefully someone else out there might find them to be useful. I can't picture myself throwing them away.
