finding signal on 97w | SatelliteGuys.US
sonia555
2
Hi guys!!! I'm having trouble finding a signal for 97w. I have a coolsat 7000pvr, single linear lnb(bullet), and a 36" Fortec dish. I'm pointing at 179.7 deg. with elevation of 55.2 deg. in my location. Can't seem to find a signal. Not sure how the settings on my receiver should be. Please, help!:o
Where are you located?
Are you using any Switches?
Did you enter the correct info in the Receiver's Setup Menu?
LNB Power: On
LNB Type: Single or Standard
LNB Freq / L.O.: 10750
Transponder: Look for 12152
I'm in Houston. I'm not using any switches. Cable is connected directly to receiver.
Your numbers lookd good.
The receiver will only show a Quality reading if the TP that is selected in the Receiver's Setup Menu is active.
Do you see 12152 in the list?
Cool Site
Line amplifier?
