Fingers Crossed on my CM 1.2 m | Page 2 | SatelliteGuys.US
no pivot bolt ?
A pivot bolt wasn't necessary.
That pivot point turned out to be a major bone of contention for a member in another thread.
He had a 1.0m or 1.2m Fortec dish.
In the end, he drilled out the dimple and the holes where it engaged, applying his own thread-less bolt as a pivot.
He also used a threaded rod for fine-tuning the elevation, and I wonder if that was instrumental in negating the drawback of the dimple-pivot?
Well, regardless, the next time I run into a similar situation, I'll keep your success in mind and re-evaluate the problem.
Thanks for your insight.
CCTV Not Broadcasting anymore on Galaxy 3C - 95.0W??
Cband interference with 90cm and 1M
