Firmware update for 722 | SatelliteGuys.US
You'll likely hear about a new firmware release here well in advance of receiving it.
There is one in the mill now (L763) and your receiver will pick it up when it becomes available by ID number (and not before).
If you run a check switch test, then shut off the receiver, it will check for any software updates. You do need to leave the receiver off for it to check. Other then that, your receiver will automatically get any update at 3 AM if we have anything.
Connect 3. Satellites to sw44
VIP 722 2nd tuner issue
