What about the SuperStation issue where wsbk, wwor, and others have the SAME episode of the SAME programScott Greczkowski said:Yes you will be able to tell it episodes marked NEW only.![]()
on the same time.
Where? I saw the issue raised, but not answeredScott Greczkowski said:I posted about that earlier.![]()
rad said:OK, who will be the first to sue E* for using some patented technology, Tivo or Replay? I'll bet some lawyer somewhere is looking over this and trying to figure out where they can get them.
Big Bob said:They will see that you are using a DVR and will not care.
You are not counted in the Nielson ratings, so why should the network care.
I never said anything about telling them you had a DVR.Big Bob said:They will see that you are using a DVR and will not care.
You are not watching the commercials, so why should the advertisers care.
sucks, but you just don't matter to them.
Also, sometimes shows are scheduled to go past the announced time by the network(bad idea, in my way of thinking), sometimes they go long because they are broadcast live, like american idol or sports (nothing they can do about that) and sometimes they go long because the local affiliate decides, for what ever reason, that they want the show to end later (the worst of all, IMHO). The last one happens more often than most people realize.
SAEMike said:Here's one thing I'd like to have included in a software upgrade. When you're watching a program, you can't delete it until you've finished it. This is pretty annoying, particularly if you start to watch it then realize you've already seen it. You have to fast forward through the entire program before you can deleted. Now granted with the 300x FF speed it's pretty quick, but annoying, none the less.
tbenning said:SAEMike, This is not true. At least on the 50x series you can delete a show you are watching without fast forwarding to the end. While watching a program, press stop and then you can delete the program. If you press "PVR" button to return to the Menu, you cannot delete the program as you suggested. In this case, press Resume, then stop, then the erase will work fine.
Limited time offer
