What is a keychain?
Sent from my Jailbroken iPhone 3GS using SatelliteGuys
Keychain is an encrypted file with all you passwords.
To see what is in it and to make any manual changes, go to Applications->Utilities->Keychain Access
What is a keychain?
Installing Mountain Lion now. During the setup a pop up ask, "Setup Assistant wants to use your confidential information stored in "InternetAccounts Access Group" in your keychain." Then it ask to Always Allow, Deny, or Allow. First, what in the heck is this? Second, which option should I choose?
I still see nothing different between lion and mountain lion. Perhaps instead of a different species it should have been a different subspecies, such as cape lion? Instead of 10.8 it should be 10.7.5. The only difference I noticed is a much much much slower boot-up and it drains the battery quicker.
Maybe if the "hype" about each minor OS X update would go away, people wouldn't expect more drastic or substantial changes. Anyone who has dealt with computers for anytime knows you don't get real "OS" upgrades on a yearly basis.Why would we expect the operating system to be a fundamentally different experience from 10.7 to 10.8? Its not like going from OS9 to OX10. There are complaints in the tech blogosphere of folks wanting to see that radical change, but I'd argue that OSX, with its increasing synchronicity with iOS has made itself a stronger OS.
Battery drain, just googling it will get you to lots of news about this issue.I have heard zero complaints about battery drain other than this report. And since I "boot" OSX about once every couple weeks, I have not noticed any issues there either.
But I disagree that it is as minor or insignificant as you suggest. There are more than 200 changes to the OS, and several of them are quite valuable. Why would we expect the operating system to be a fundamentally different experience from 10.7 to 10.8? Its not like going from OS9 to OX10. There are complaints in the tech blogosphere of folks wanting to see that radical change, but I'd argue that OSX, with its increasing synchronicity with iOS has made itself a stronger OS.
AirPlay alone is worth the $20, but add everything else, and an excellent OS has only gotten better. Yes, not forcing the user to make radical changes, but I don't want or need radical changes.
As far as the 200 new features go. I too read that on their website. Look at what most of these features actual are. Most are just upgrades or tweaks to features that already exist. The few new things they list are not specific to the OS, but are add-on apps or features to other programs (such as Safari) which has nothing to do with the OS.
Here's something interesting.
Many of Apple's apps will save to iCloud. Those files are also save on your Mac too in your local library -> Mobile Documents folder. So you have a synced file on your local Mac, in the cloud, and available for your iOS device.
Once a file is saved in the Cloud, then the next time you run the associated app and click file->open, you get a dialogue window showing you both the iCloud and local files. You can even save TextEdit files in the cloud and get to them from other Macs from the cloud. You can't see them from an iOS device because there is no app for that.
But here's a trick! Open textedit as an app IOW, don't select a document. It will open with the dialogue I told you about. Now you can drag 'n drop ANY file into that 'sandbox' in iCloud! Of course, if textedit can't use it, it is just an offline storage area.
So far I've tested with Pages, Numbers, TextEdit and Preview. All work just that slick!
I had previously talked about the Mobile Documents folder because I couldn't find out any way to stuff files there except manually. But if you save your files to iCloud, then they are also in that directory too. And any time you edit them, they will sync across all your Apple products that have iCloud support.
One other thing I found out was that my current iCloud has 25Gb of free storage! I know that Apple gave it to us that came from MobileMe, but it was supposed to expire at the end of June 2012. While I'm glad it is there, I'm afraid to use that extra storage.
That is the way I too would describe it. The change between Snow Leopard (10.6) to Lion (10.7) was much greater than that between Lion (10.7) and Mountain Lion (10.8)To me this update was more of a service pack then an os upgrade.
I could be wrong - as it happens occasionally - but I THINK that the App Store is tied to the hardware you are running it from - so if you were not eligible to purchase/install something, it won't let you. But again, just a guess.
Tests show Mountain Lion may indeed degrade battery life
Our testing shows noticeable decrease in battery life on the Retina MacBook Pro.
by Chris Foresman - Aug 7 2012, 4:30pm PDT
Some bit of software within Mountain Lion indeed appears to noticeably reduce battery life for Apple's portable Macs. Following on numerous reports lodged in Apple's support forums, we did some additional testing using our Retina MacBook Pro review unit, which seemed to lose approximately 38 percent of its previous 8-hour runtime after installing Mountain Lion. Apple support technicians are continuing to gather evidence from users reporting problems, though at least one user has been told that an update from the Mac App Store should address the issue.
Limited time offer
