I also highly recommend the extra 18" ribbon from mouser as that can be left in the receiver.
Could you post the part number here? I wonder if the local radio shack stocks it.
I had posted a link on page 12 of the instructions right under the one photo of the extension ribbon cable.
1M-1010-010-3365-018.0-00-AB-00-0 3M Electronic Solutions Division | Mouser
Mouser Part #: 517-1M-1010-010-18
Manufacturer Part #: 1M-1010-010-3365-018.0-00-AB-00-0
Manufacturer: 3M Electronic Solutions Division 3M Electronic Solutions Division
Description: Cables (Cable Assemblies) 10P 18" SKT - SKT 28AWG STRANDED PVC
Would a Tadiran TL-5955 2/3AA Wire 3.6V Lithium Thionyl Battery from ebay work for a battery in a 4dtv 920 receiver?
...It is zero and so you are on UTC time and have no timezone information...
Oh yeah, and now the guide works too. (Pretty cool).
So you like that guide eh ?
PrinceLH said:OK, tested the IRD(921) and found that the IRD number is intact, so I can now go about the task of changing the battery. I assume that you get the rack out of the way, so you can reach it, then you plug the machine in, while you do the replacement. Checked some prices for the replacements, in Canada, and found that they're all over $20.00. I see that Radio Shack has the 3.6v lithium batteries, for around $10.00, stateside. I have to go on Friday anyway, so I'll pick one up then.
When I looked in the channel map, from 2001, the last time I activated it, it showed 31 satellites in the buffer, 7 that were programed in. I intend to sub it for a couple of hours, from Shaw Direct, since I have a subscription there already, and that should reset the clock. I don't intend to do a master reset. I should be able to use all of these spare satellite tiles, to program the current satellites, in the sky. If this all works out good, I plan on adding my Viewsat 9000, using the 921 as the slave unit.
Any other tips out there?
Limited time offer
