GONE - FOR SALE: Amiko Mini HD265 $45 | SatelliteGuys.US
GONE FOR SALE: Amiko Mini HD265 $45
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
27,021
7,345
EM75xb
This is a Amiko Mini HD265 that a customer returned. Said they couldn't get a dish set up or something. It is clean and loaded with the latest firmware and NA satellite list.
Price includes shipping to CONUS. PM me if interested.
With real time sync via the internet. No more incorrect clock. Clock is always correct, if internet connection is present!
  • 6000 channels (TV and Radio) programmable
  • HEVC decoding support
  • Two High Speed USB 2.0 Connections
  • Ethernet Connection & USB WiFi Support (Ralink RT5370 chip only)
  • YouTube videos
  • RSS Reader & Weather Forecast Functions (Ethernet or WiFi connection required)
  • DiSEqC 1.0, 1.1, 1.2 and USALS Compatible
  • Full HD (1080p) Output via HDMI
  • Channel Recording to External Storage Devices
  • Timeshift support
  • Channel Recording & Timeshifting Simulteniously (optional)
  • Channel switching time less than 1 second
  • True-color, User Friendly On-Screen Display (OSD)
  • Full Picture In Graphic (PIG) function
  • Electronic Program Guide (EPG) for on screen channel information
  • Subtitle supported
  • Parental lock facility by channel and program event
  • Program and Channel information transfer from receiver to receiver
  • Multi-Language support
Tuner & Demodulation
Tuner Type: DVB-S / DVB-S2
Input Connector: F-type, Connector, Female
Signal Level: -65 to -25 dBm
LNB Power & Polarization: Vertical: +13V/+14V,
Horizontal: +18V/+19V
Current: Max. 400mA
Overload Protection
22KHz Tone Frequency: 22±1KHz
DiSEqC Control: Version 1.0, 1.1, 1.2, USALS
Demodulation: QPSK, 8PSK
Input Symbol Rate: 2-45 Mbps,
FEC: 1/2, 2/3, 3/4, 5/6, 7/8 and Auto
System Resources
Main Processor: 594 MHz based CPU
Flash Memory: 16MB
DDR RAM: 256MB
MPEG TS A/V Decoding
Transport Stream: MPEG-2, H.264, H.265
Input Rate: Max.120Mbit/s
Aspect Radio: 4:3, 16:9, Letter Box
Video Decoding: MPEG-4/H.265 SP@L3 to ASP@L5, AVC, HP@level 4.1, MP@level 4.1
Video Resolution: 720*480P/I, 720*576P/I, 1280*720p, 1920*1080i, 1920*1080p
Audio Decoding: MPEG-1 layer I/II, MPEG-2 layer II, Dolby digital
Audio Mode: Left / Right / Stereo/ Mono
Sampling Rate: 32, 44.1 and 48KHz
Power Supply
Input Voltage: 12V DC
Power Consumption: 24W Max
Stand-By Power Consumption: <0.5W
A/V & Data Input/Output
AV Out: Jack to RCA (CVBS Video & Audio L/R output)
USB: Two USB 2.0 slots
S/PDIF: Coaxial
HDMI: VER1.3, Type A
Ethernet: 10/100M RJ45
RS232: Jack type
Physical Specifications
Size[W*H*D]: 144mm*40mm*110mm
Net Weight: 0.5KG
Operation Temperature: 0°C~+45°C
Storage Temperature: -10°C~+70°C
Storage Humidity: 5%~95% RH (Non-Condensing)
Great price! Elsewhere it lists at $105 and ships from eastern europe so it would take them like 2 months to get it to buyer.
No, I sale them from here in the US also. ;)
Thanks, but NO thanks!!! :)
Sorry, it doesn't support "CC"
Closed Captioned for the Deaf and
hearing impaired.
I think it does. That's what "subtitle supported" means. I can double check when I get home tonight if you want.
Not the same CC as in the US. We are odd over here, from the rest of the world.
Ya, make sure that your TV support Closed captioned. I like Electronic Close Captioned by the TV which has a VBI 21 Lines for electronic captioning. White text on black bar. That what it should look like. Either white or grey, depends on your TV set.
Thanks,
Eugene
SOLD
Thanks for looking Guys!
new 1.2 meter dish and 12 footer
