Fortec Classic PIN | SatelliteGuys.US
Fortec Classic PIN
zeusTheDoc
28
Hi guys,
Is there a ways I can turn that PIN off so that my receiver doesnt ask for it everytime I turn it on, its a kinda nuisance.
tc
~Zeus
I've read that Fortecs have a feature which allows for parental locking of entire satellites (not just individual channels), and that this lock is enabled or disabled via the satellite setup/installation menu.
I'm reasoning that, if the receiver is powered down while tuned to a locked satellite, it would again ask for the PIN immediately upon being turned on.
I can't verify this information as I don't have access to a Fortec. Good luck.
zeusTheDoc said:
Hi guys,
tc
~Zeus
Are you saying when you turn the box on it asks for a PIN? Mine only asks when I go into the install menu, channel menu, etc. If I dont go in the menus I dont need it
Is it possible to dump the channel list to a pc, restore defaults on the receiver, and then reload the channel list ? Or would you be so unlucky that the problem would go with your channel list. Could it be a mis-guided parental control lock ? ( I've never even looked at that on my Classic , why I ask ) .
I dont know brent. I always thought that when you upload a channel list, its just that. the channels. And all other settings can be reset
well .. you were right, i turned the sat lock option to OFF and now its doesn't ask for PIN.... thanks ;)
Toshiba 1520 question
Here's something to look for
