FTA receiver with built in positioner?? | SatelliteGuys.US
phpinfo
294
USA
I am considering getting an HD FTA receiver to upgrade from the Coolsat 6000. I am also looking to get a Gbox or V-Box positioner.
Are there any HD FTA receivers with built in positioners?
- Also, are the Gbox and V-Box the only options for positioners? - I did find another site, but not sure I trust it. NINGBO SENFU MACHINERY&ELECTRIC
no, I don't think so:
There was a receiver with a motor controller built in, but it was standard def, and kinda rare.
There are some Pansat models which can run the feedhorn servo motor, but they are standard def, too.
I am not aware of any Hi Def receiver which will run either the main dish-mover motor or the servo motor.
You are pretty much restricted to the voltage select LNBF's, or an orthomode feed with two LNBs for each band (and some multiswitches).
Then in the dish-mover department, the Gbox v3000 is the only real choice.
See more about it in our Review Department.
After discussing the device during the review process, I liked it so well, I ordered one. :)
Power Drill
EBAY FEEDS A question for Scott
