G1 / Guide | SatelliteGuys.US
G1 / Guide
Hutchie
6
Barbados
Hi all,
I am having some trouble picking up the guide and any channels on G1. I live outside of the U.S. which might make it a bit difficult but I do pick up most other satellites (G5, G9, C3, C4, G3, etc.). The only one I seem to be getting difficulty finding is G1. The signal jumps between 10-100. I have a 12" mesh BUD.
Any ideas? I can give you any settings or my exact location on google maps if necessary.
Thanks guys.
You should stabilize the signal first.
Have you adjusted the Dish and Skew?
I have tried to adjust the dish and skew but can't grab anything that is stable.
I know the dish numbers are relative but this is what I currently have
G1
Channel 3
Dish: 4996
Skew: -65/90
Signal: Jumping 100 to 10/20
Quality: 1
Unstable
C4
Channel 802
Dish: 5020
Skew: 90/25
Signal: 100
Quality: 61
Stable
C3
Channel 686
Dish: 4965
Skew: 90/10
Signal: 100
Quality: 46
Stable
I posted the C3/C4 since they are either side of G1 and I get them fine.
G1's footprint drops off sharply south of the border. The only thing you can do is get a bigger dish.
Does the guide only come on G1 or is there another way I can get it? :S
167 resolved to tell me what channel it was and that there was not an active subscription, which none of the other channels did. This happened when I was playing with the settings.
Is there a dish/skew starting point I should start at based on C3/C4? Right now I'm shooting completely blind changing dish 1 then skew through the entire range, then dish again etc.
I guess that means I'll need a huge dish and a lot of real estate when I move to Costa Rica after I retire. :eek:
(Either that or become more proficient at Spanish).
BUD with doble feedhorn
Fox News Out?
