Galaxy 19 tp 12184 | SatelliteGuys.US
Galaxy 19 tp 12184
kickboxer
52
3
Hello everyone.
I am getting every other transponder on Galaxy 19 97w with a quality of in the mid 70's but I somehow can't get tp 12184 H (p) 22500 (sr) to tune in. I have tweeked the dish/lnb but can't lock that tp for some reason. Any suggestions? Thank you in advance.
What size dish? That frequency is DVB-S2 8PSK, so it would be more difficult to tune than the others, the majority of which are DVB-S.
Thank you so much for the reply. I have a 39 inch dish. It's weird though, all other tp listed on lyngsat do come in green with quality of 75.
Yes that's the one! Yes makes sense now. Every other tp is DVB s and this is DVB-s2. Do you recommend any inexpensive receivers? Thanks :)
I'll defer to others, like KE4EST and Hyper Casey since I haven't bought a receiver in a while. One of those 2 guys will point you in the right direction
I may have misread the manual; it didn't look like it had support for S2
Weird, the manual you had posted didn't have DVB-s2 and the one I had found does. Maybe two different receiver versions? I guess the only way to find out is by getting a fully compliant dvb s2 receiver lol.
