galaxy 19 | SatelliteGuys.US
galaxy 19
CO2
16
Using a Star Choice dish with a linear LNB will I be able to get a signal from this satellite?
Yes, you should be able to. I used to have a 30" Star Choice dish and was able to receive Galaxy 19. There might be some weaker transponders you will not get. It also depends on where you are located, I guess.
I would think you would in most of North America, I myself have a round 36 inch dish with good reception. Linear LNB indeed,
What type of dish is it? The round one or the elliptical one with the quad LNB?
I use to have a SC 75e dish for 97 & 101...worked really good
TSreader and VLC
Gal 18 @ 123*W KU
