I got my gbox 2 days ago and setup the c band this afternoon. Had to have my wife lift it up on the pole. Set the elevation 1.5 deg higher than where i lived up north and hooked up the gbox and cs4000 pro and had to keep clicking the remote till I got near my true south sat (87) and had put in the proper freq and I hit My Network. Is there a way to hold the move east and west button down or do you have to use the 1 click for one bump movement? After I tuned in 87 AMC 3 I named it and resynked it. Even went into the cs and set it up for 1.2 and saved My Network as a favorite but it would not move after I moved it off to the east and choose My network channel it did not come back to it.
Can I use switches before or after the gbox? I have 2 lnbs on the c band. Also want to add a dual linear ku lnb on the side of the scalar. Could I hook up from the gbox to a zinwell 6x8 then 4 coax from the zinwell to the 2 cband and 2 coax to the dual ku?
Any suggestions? Do I need more than one sat setup as 1.2? thanks for any tips.
