Have you tried a converter box?My Off The Air channel count will soon = 0 once they flip the digital switch.
From what I understand, "they" are not pumping full power on the Digital antenna.Yes. I am very rural. I have been messing with a huge VHF OTA antenna and now I occasionally can get some channels now.
Yes. I am very rural. I have been messing with a huge VHF OTA antenna and now I occasionally can get some channels now. Nothing solid but I was able to watch about 10 minutes of the super-bowl. We are just on the threshold for signal strength for the new Digital TV. I have messed with amps and what not. There is no easy fix.
I really don't care but the thing that makes me a little mad is that I get 2 or 3 analog stations very, very strong but none of those come in at all with digital. My hunch is that they either have not or will not be transmitting the digital from their current translator sites.
Ok, let me clarify
You have 90 memory spots for satellites.
There are 60 Names already preset into the GBOX. 30 Names not pre-set.
At any of the 90 spots, you can tag it with a satellite name. The name tag can be pulled from anyone of the pre-stored 60 names, or you can customize your own name by using one of the available 30 empty spots.
All of this is also explained in the manual and how to use the remote control to do it.
Limited time offer
