Thanks for your fast answer and YES unfortunately for me your are correct. So far I was fortunate to separate them using a existing routers with assignable lan ports with different subnets. I wish there would be an easier solution to this. Its weird once both gennies are on the same lan only one SSID is broadcasted and all the clients wanna connect to that one. Crazy part is that we are doing series of houses with no coax inside at all. We using existing fiber to home infrastructure and that's why we have to use wireless clients for every TV and many of them more than 15 per house.I can't recall if the hidden SSID is generic or if it includes something unique like the last 4 of the receiver ID. It would be logical to be a unique ID, as apartment buildings or homes may be close enough to pickup two of the same unit. The hidden SSID is not a user configurable option.
That said, do you have two HS17 on the same SWiM or LAN network? If so, that is the problem, you can only have one server with the HS17. Clients can't pick between so to speak, which is why they only allow one on an account. If you have two HS17, possibly two accounts, you will need to find a way to isolate them and have clients on the network for the server you want them to see. That would mean separate dishes (or separate feeds from the dish with band-stop filters installed, and only connecting one to the internet or having one connected through a separate network IP range (second router or a vLan isolated from the other).
That would be quite a unique setup if you had to go that route.
Thanks for your fast answer and YES unfortunately for me your are correct. So far I was fortunate to separate them using a existing routers with assignable lan ports with different subnets. I wish there would be an easier solution to thisIts weird once both gennies are on the same lan only one SSID is broadcasted and all the clients wanna connect to that one. Crazy part is that we are doing series of houses with no coax inside at all. We using existing fiber to home infrastructure and that's why we have to use wireless clients for every TV and many of them more than 15 per house.I can't recall if the hidden SSID is generic or if it includes something unique like the last 4 of the receiver ID. It would be logical to be a unique ID, as apartment buildings or homes may be close enough to pickup two of the same unit. The hidden SSID is not a user configurable option.
Video Player is loading.
Play Video
Replay
Unmute
Current Time 0:19
Duration 0:19
Loaded: 0.00%
Stream Type LIVE
Seek to live, currently playing liveLIVE
Remaining Time -0:00
Playback Rate
1x
Chapters
Descriptions
- Chapters
Captions
- descriptions off, selected
Audio Track
- captions settings, opens captions settings dialog
- captions off, selected
Fullscreen
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
TextColorWhiteBlackRedGreenBlueYellowMagentaCyanTransparencyOpaqueSemi-Transparent
BackgroundColorBlackWhiteRedGreenBlueYellowMagentaCyanTransparencyOpaqueSemi-TransparentTransparent
WindowColorBlackWhiteRedGreenBlueYellowMagentaCyanTransparencyTransparentSemi-TransparentOpaque
Font Size50%75%100%125%150%175%200%300%400%
Text Edge StyleNoneRaisedDepressedUniformDropshadow
Font FamilyProportional Sans-SerifMonospace Sans-SerifProportional SerifMonospace SerifCasualScriptSmall Caps
Reset restore all settings to the default valuesDone
Close Modal Dialog
End of dialog window.
In reality there are 2 accounts and it is a hassle physically and accounting wise.How do you have two HS17’s on one account? Are you a beta tester?
Limited time offer
