GERRY 1 starchoice | SatelliteGuys.US
GERRY 1 starchoice
gerry1
does any body knows :confused: :D what type of lnb i need for anik f1 and anik f2 , STARCHOICE ....i reside in san franscisco , any ideas about the skew , ele and azimuth for the installation of thiese dishes ........................thank you gerry1
60cm elliptical would work; but 75cm would be much better (way less rainfade). You can get all alignment info for your area at Mike Kohl's Global website.
You can use the 75cm eliptical dish, which would give you both satellites. I think a 60cm wouldn't work, as the signal drastically drops off once you are outside of Canada. I'm in MN and got a 75cm.
Another option is you could use 2 dishes and tie them together with a 22khz switch.
The LNB's are KU band, and not the DBS LNB's that DIsh and DirectTv use
