Getting HD | SatelliteGuys.US
Getting HD
thomasrp
2
I am getting the 811 installed next week (I think it will be an 811 :)). I currently have the reqular receiver DP301. The Dish network guy will take away the 301 and replace it with an 811.
My question is since I have a sony HDTV with an HDMI input, will the Dish network guy provide me with a HDMI cable or do I have to buy one myself. If he does not use the HDMI, I am guessing he will use the regular RCA.
Will there be any need to rewire the coax cable for HD (this is a new house and came prewired with coax cable which the 301 is currently using)?
Thanks in advance,
-tom
Hi Tom, welcome to sat guys!
The only HD cable that Dish provides is a component cable.
The satellite hook up that you have for the 301 will be fine.
If you want to use your tv's HDMI, you'll need to get a DVI to HDMI cable, but in actuality the Component cable will do just fine.
New install, lousy picture
What exactly is the difference between a DPP LNB & DP LNB?
