Getting OTA HD w/ Built in Tuner on Sony KDF-55XS955 | SatelliteGuys.US
Photai
14
5
I'm new at this, I just got a KDF-55XS955 and I'm trying to get my locals in digital quality and receive HD prog. I live only around 4 miles from the stations, zip code 33180 and I have a Terk TV5 set top antenna. When I connect it to the VHF/UHF port on the TV and do a channel search nothing comes up at all. If I connect it to the cable input and do a scan ill get 21 analog and 4 digital stations but when I go though the channels they all look very fuzzy and ghosted (just like it would look on a regular tv). I think either I'm doing something wrong setting the TV up to get the digital channels or the antenna is broken since I'm only 4 miles away in a 1 story house with no major obstructions between my house and the tower.
Can anyone suggest what the next step would be to get this going. Thank you.
next to the zero button on the remote is a "." button. As said before click 5.1 to access the digital channel of 5
from antennaweb.org it shows that some channels available are
42.1 PBS
29.1 FOX
17.1 PBS
4.1 CBS
39.1 WB
33.1 UPN
10.1 ABC
7.1 FOX
2.1 PBS
6.1 NBC
some of these stations are very close to you but still say you might need a medium sized antenna. Also this site isnt always 100% accurate
