I dont understand the point of the post, but OK. Whatever
There is one minor error
if the diseqc is port 2, then you do not turn the 22k on. The 22k is only for Universal LNB's (which the Glorystar system uses Standard LNB's) or if you use a 22k switch (Glorystar system uses a diseqc switch)
Does this matter now that the satellite is changing to Galaxy 19?
Yes, but who will fill the void? That is the interesting question that I look forward to seeing answered.Of course, the majority of new growth and channel placement will now occur on 101W. Only a few channels are moving to G19 and the departure of these few SCPC channels will open the satellite to many MCPC channels!
Google (among others) is your friend! Here's the top result from Google:What is SCPC and MCPC?
So, the efficiencies of MCPC will require more uplink coordination than was enjoyed in the past with SCPC.SCPC stands for Single Channel Per Carrier.
SCPC is a form of satellite transmission where each channel is transmitted on a dedicated single carrier.
The alternative to SCPC is MCPC (Multiple Channel Per Carrier).
MCPC is more efficient than SCPC, but SCPC is still utilized for some satellite feeds. By using SCPC, satellite users are able to uplink to the same transponder from multiple locations.
Limited time offer
