I just returned from an 8000 mile three month road trip and set up the Glorystar package several times. It never took more that 10 minutes to set up and get both sats going! The only change I will make for the next trip, will be to take my surveyors tripod along with the Wingard post base to level and hold up the Dish. Trying it at home, now, and it looks like it will be stable to a least 20 MPH winds! Four one gallon milk jugs of water hold it steady.
That being said, I have seen several questions about whether or not a greenhorn can install the Glorystar system. I will say YES! If you choose to add a motor, I can not say that for sure, but the "fixed two sat" system, yes! The ONLY thing I will say to be ready for is for the 1/4" by 5/8" carriage bolts supplied are not the best quallity for the azimith clamp (rotational). I went to HomeDepot and got some hardened ones after breaking 2 sets of them. Now my dish does not swing in the wind, even at 65 MPH. (No, I do not have the dish out while I am driving - winds at the property are wild!)
I have since picked up two more dishes and receivers and they are no where near as easy to set up - even as fixed systems. Brian - Glorystar --- you did good. If you want to consider this as a review - OK - And a big thank you for an excellent product that you stand behind - or in front of!
