"Go to first new post" not working | Page 2 | SatelliteGuys.US
Not open for further replies.
Working now on my iMac G5 (I know, its old), OS 10.5.8, Safari 5.0.3.
Not working on my work computer.
Dell Laptop. XP SP3. IE-8
If I press first new post it puts up a blank page and stops.
Update: It works if I go to first page of thread and press the first new post button there. It does not work from the index page by pressing the down arrow button for first new post. I am looking off the search page. I will now go check a normal index page.
Update2: It is working ok if I go in the 'normal way' and select a forum, choose a thread and hit the first new arrow. It does not work if I search all forums for new posts and then select a thread and go to first new.
Yes! Works for me now, even on my ancient version of ff. (I use the little blue circle with double down arrows ahead of the thread.)
Sweet, working here too. It is amazing how something so "little" makes such a big difference in the SG experience!
Now its NOT working for me, all I get is a blank page when click on the icon for for goto new post.
here's a sample of what is in address bar.
http://www.satelliteguys.us/showthread.php?t=236517&goto=newpost
Kevin...
I am not sure why you are seeing the URL's you are seeing...
The correct url for that thread is http://www.satelliteguys.us/dish-network-forum/236517-does-pro-switch-44-really-need-new-post.html
Are you running any kind of Ad or Java blocker on your PC as its not correctly formatting it and you are seeing the old non SEO'ed URL's.
This just started, I first noticed it when I got home this morning (2 am CST). I am using FF with the ad block add on (only set to block ads on AVSforum) I have made no changes on this end.
UPDATE: Same thing happens using IE8
Can't edit my last post, also does the same thing on my netbook. IE 7 or 8 not sure which, forgot to check before turned off.
Also same problem on my droid browser in both pda & non pda modes.
These are the same links I see using RSS in Firefox. I also get a blank page.
http://www.satelliteguys.us/showthread.php?t=236547&goto=newpost
Yet when I click on the above link in this post I get this
http://www.satelliteguys.us/dish-network-forum/236547-question-about-harddrive.html#post2402718
Kevin...
Using OS X 10.6.5 and Safari. I click on New Post (Entire Site). When I click on the Go to the first new post button (looks like a down arrow) I'm taken to a blank screen. If I click on the thread and then click on the Go to first new post button it works. So it works if I'm in a thread but not looking at the list of new threads.
Deleted threads retain titles?
Memberlist Function DISABLED
