Good blower for my gas log fireplace? | SatelliteGuys.US
Comptech
3,648
2,803
Travelers Rest SC
What have you had good luck with for circulating the warm air? I have two 120mm ac fans in there now. Have a wiring problem in the wall that I am getting now power to the fans. Wires have been removed from the switch, so I an looking for a squirell cage type with a 120 plug to install into it. Any suggestions?
Cant find the exact one I used? This is the type there are many that work great. Make sure you can get Stainless Steel.
Reactions: navychop
Ready for the next adventure!
