GEOSATpro - GSP MicroHD channel editor Muzak PID issues | SatelliteGuys.US
GEOSATpro GSP MicroHD channel editor Muzak PID issues
oldsmobile
157
111
Central PA
I am trying to add the Muzak / mood channels to my GEOSatpro MicroHD using Mediabox Editor Studio (MES). I'd done this a few years ago, but in the meantime, my original MicroHD died and I must have deleted my .udf files.
What's happening is that although I am able to add the correct audio pid in MES, and the MicroHD will play it temporarily, it will not display the correct audio PID. I can play the channel, and then when I move to another channel, it'll revert to the MS81 that I had copied & pasted as my channel to modify.
Can anyone look at this screen shot and tell me what setting(s) need to be changed? Thanks in advance for any help!
It also worked on my microHD for one channel! That means all will work. I need to get to work to add the remainder for the New Year's party on Saturday.
Edision New guy looking for help
Openbox Daily Timed Recording Problem With Openbox S9?
