h20 going BONG BONG BONG BONG | SatelliteGuys.US
mots-a
93
Howdy -
Turned on my h20 tonight to view some hd and now I have a problem - all the channels work fine but I am getting that BONG SOUND along with the tv audio - its the BONG sound that the h20 makes when you enter a wrong channel or run the guide to the end.
So along with the tv audio I get a constant BONG BONG BONG BONG....
No buttons are stuck on my remote.
Any Ideas?
Howdy -
Any Ideas?
Reset it!
H20 Bong, bong
Click MENU>SETTINGS>SetupScroll down to
Audio:down>CLICK>scroll up:up to Language>Right to Sound effects>CLICK>CLICK OFF:eureka
End of Bong, bong!:tux:
LOL
Thanks all -
I did reset three times, the third reset fixed it.
Thats where I was going to go with it, had he said he had a HR20, I did not know if the H20 had the same options.
Good call :)
Jimbo
hr20 bong
I got also fixed it last week by reseting it worked. It happen last night bong bong bong had to reset it what is up
fixed bong, bong, bong without reset.
I had the same thing happen last night when my wife pressed the 0 key before the chanel number on accident; was able to fix it by pressing 0000 on the remote.
I've had D* for only two days now and yesterday I got the BONG! Pushed the "dash" key on the lower left corner of the numeric keys and it went away.
I have a real one around here someplace. Haven't used it in years, but I just can't seem to throw it away. I guess I'm holding onto the distant past! :D:D
Same here. I put it in a box somewhere and can't remember which one. It's been years. Years!
I can picture my kids going through all that stuff one day. "Hey...lookit this!"
Existing Scheduled Recordings and new HD Channels
Ready to buy HD DVR, got a question.
