H20 HDMI problems | SatelliteGuys.US
H20 HDMI problems
markrubin
19
Happy Holidays!
I have had an H20 (with a 3 LNB Dish) for 2 weeks now and am having HDMI issues
firmware is 0F03 (it took this firmware update and it made no difference)
typical problem is runnung HDMI to a Sharp LC-26 LCD: the Sharp displays 1080i for a second, then defaults to a VGA resolution: I can go into the Sharp menu and fix it, but it happens again every time I turn the TV back on
another problem is going thru Gefen HDMI splitters: my Dish 942 works flawlessly through two of these splitters: the H20 will not
I have tried every combination of cables, settings, etc with no improvement: I think the H20 is defective
any ideas? anyone else seeing this?
Thank you
Similar problem??
Ive had my H20 in similar configuration for the same timeframe but mine just blinks for a second and then resumes the picture?? My firmware was upgraded on Dec 28 to 0f03 and I called directv and said they didnt have a record of any reported problems. I checked my cable connections and swapped the HDMI cable for a better quality one and the problem has not reoccured. Magic??
Local Station Availability
HD lite
