H21-200 CE Release 11/14 0x429F | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,047
452
Central Michigan
Systems in this release
H21-200
Window of opportunity to download:
Friday, November 14, 2008 11:00PM - 2:30AM ET
Saturday, November 15, 2008 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
Differences based on last National Release
[/B]
  • Items from CE:17:01 High Risk
New features
  • 01 - Network
  • 01 - Media Share
  • 01 - Music Screen Saver
  • 01 - Game Search
  • 01 - 1080p/24
  • 01 - OTA via the AM21
  • 01 - Autotune
  • 01 - Multi-Room Viewing
    • View Playlist from a networked HR2x or R22
    • Playback/Trick Play functions from any networked HR2x or R22
    • Press {LIST} to see HR2x or R22 servers
    • one playback per server at a time
Improved/Updated
Notes
  • 01 - Reverting back to National Release will go back to
    default settings
  • 01 - To enable MRV:
    • Network must be enabled
    • Enable IAMANEDGECUTTER keyword
    • Select Menu -> Parental, Fav's & Setup -> Miscellaneous Options -> Multi-Room
      DVR and choose On.
    • Network must be enabled on HR2x and R22 DVRs
  • 01 - Please test the box as a standard H21 before enabling the
    Multi-Room View Client feature and report issues
  • 01 - Then please test MRV
    veggies before dessert
  • 01 - When reporting MRV issues, please include the logs from
    both server and the client
  • 01 - Please report all occurrences of "Unable to Access
    to Media" OSD with logs
*** CAUTIONARY NOTE *** You've been warned
  • 01 - Do not have an unpurchased PPV in the server's
    playlist when displaying the playlist on the H21
  • 01 - Do not have a currently downloading broadband program in
    the server's playlist when displaying the playlist on the H21
Pay careful attention the the special Cautionary Note before using MRV.
Looks like you could be billed for PPV simply by having them recorded, if you use the MRV feature (possibly even without watching!)
If you record PPVs for future viewing, you may want to wait on MRV.
Also note the warning on VOD downloads.
Can't wait for this one. I figured that they will never upgrade the H20's so I picked up an HR21-200 today.
If one of the lucky guys with an H21-200 could snap some pictures of the list and what you see it would be appreciated by all us dvr-only folk :)
On some slingbox players there is a setting you need to turn off for a print-screen capture to work. VMR is the setting you may need to turn off. Not sure if it will affect you, but just in case :)
Here are some pics. I will add more as I grab them.
Here are a couple more. Notice that I am playing an HD feed from my HR20-100. :D
I have already found one issue with MRV. I have deleted a show on my HR20 and it still shows on the H21. If I try to play the deleted show I receiver an error that the media file does not exist.
Maybe it doesn't delete on the other till it's been shut off and turned back on, sorry I can't help play with this at this time.
Jimbo
Maybe it doesn't delete on the other till it's been shut of and turned back on, sorry I can't help play with this at this time.
Jimbo
Looks like there is a refresh interval for the play list. The recording that I deleted is now gone from the view on the H21.
Also, I just recorded something on the HR21 and it doesn't show up in the H21 list right away? Shows I had recorded earlier today are showing up fine.
Give it a few minutes, it could be the same thing Jag found, it takes a little while to refresh.
Jimbo
It would also be really nice if you could name your DVR's instead of having the RID number show up. When this is all said and done I will have 5 DVR's and it will be difficult to remember which one is which without a rename option.
