I have tried with two recievers thus far. Nothing.
my friends says his 2 took the update A-OK
Both running the CE and no issues so far. The first thing I did was turn off the Power Saver
I notice that the DVR has the YouTube feature but the receiver does not. Only the DVRs can do YouTube?
Sent from my iPad using SatelliteGuys
hedbert said:Correct. But others have not been labeled very high risk. I run beta software at work all the time. I am just weighing the risk with this one.
Man. The slower receivers in my house are the ones that need this update the most. I can't get them to find it. Ugh.
Okay. I can see this power saving feature as being really annoying. While the intentions are great, the 2 hour shut off isn't. Was watching football and wasn't paying attention when the prompt came up, but it just turned off my box. So, either there needs to be an adjustable time to turn off, or a longer time. I would imagine the 2 hour limit would be annoying when trying to watch a movie.. or in my case football.
You do know you can go into the menu and adjust it to OFF?
Are you waiting until the CE release is available? It's midnight to 3 AM I think. You can check it here: DirecTV Firmware WatcherIm doing the same way I did the hr 24's..Of course if we could just get the NR none of it would matter
Agree also. It would be very easy for them to add longer timeout options. Just a few additions to the menu would make it a useful feature.I agree. Adjustable or longer timeout. Had the same issue with lord of the rings.
Limited time offer
