Won't happen. Fewer and fewer of the channels have a cropped SD feed. They don't think it's worth the money, for an ever-decreasing SD market.
Well, DirecTV needs to crop it for the SD customers just like they do with the local channels.
But why is there a feed for the sd channel of 312 on 101? And why doesn't the hd logo show on 312 sd if it's really the same feed?
Because the SD feed is Center Cut from the HD feed. So you loose the wings of the HD feed on the SD side.
So the bars I'm seeing on the sd feed aren't in the signal, they are produced by my tv? That would make sense.
It's the CONTENT that is the same...But why is there a feed for the sd channel of 312 on 101? And why doesn't the hd logo show on 312 sd if it's really the same feed?
I just turned on 312 HD feed and there is a "HD" logo in the black bars
when you turn to 312 SD feed it fills the whole screen. no "HD" in the corner which contradicts what the OP is showing
Technically, both. The SD feed of channel 312 is the same thing as the HD feed, there is no separate feed of it that Hallmark sends.
Are you sure??? Unless it's changed recently, according to this they send separate SD & HD feeds for all channels/time zones, on the same x-ponder 5:
http://www.lyngsat.com/AMC-11.html
Lyngsat data is often outdated.
Like I said, I think we are all saying the same thing...
YES... there are separate HD and SD feeds uplinked...
YES... there are separate HD and SD channels for the regular Hallmark Channel on Directv.
YES... the SD version of the channel is identical to the HD. Sometimes, it's chopped, sometimes it's letterboxed.
Somebody somewhere is taking the HD feed of the channel and "creating" an SD feed and something is supposed to tell it when to chop. Personally, I think it's Directv only because that is how many locals are created. Many local channels will confirm to you that they only send one HD feed to providers and they are the ones who alter it to create SD feeds. But, at the end of the day, Hallmark SD is Hallmark HD downgraded to an SD signal in a varying aspect ratio, regardless if Directv or Hallmark is doing it.
This not always the same process that most channels use, as others have listed. ESPN HD and SD are the same, that's why ESPN stopped writing "ESPNHD" in the wings when they went to all 16:9 graphics. But when the "HD" is shown on the SD channel, it's probably Directv.
Limited time offer
