Hard Drive Bargain Watch | Page 40 | SatelliteGuys.US
Too bad nothing bigger than a 1TB works on a 211/211K. :( Good deal @ Costco.
just picked up a Segate 2 TB HDD from Costco. $20 off total with tax and shipping...
$131.23
formatted fine, now just switching cables and putting everything from two 500 gig and one 1 TB drive on it. having to clear the DVR HDD download from old to DVR then upload to the new big drive.
you can try a version of the freezer trick.
when a hdd starts to fail some have had luck freezing it and then reinstalling it, long enough to save file etc. not sure how you could do this with the whole receiver,but maybe you can chill it long enough to get something extra out it.
just a last resort
The ideal solution would be to build a RAID array, consisting of, for example, 2 or 4 1 or 2 TB drives, in matched pairs, one half of each pair acting as a mirror to the other. Then you would have the advantage of larger storage sizes, and you would never lose anything (the small ones fail too). Unfortunately I don't know if the DVR's support that kind of configuration (I've only seen it on PC"s).
There are several USB Raid Controller solutions available here: USB RAID System
There's a USB RAID LEVEL V - with 4 drives, all must be the same size and you loose the capacity of one drive, ie: N X CAPACITY - CAPACITY OF ONE DRIVE = RAID CAPACITY.
Theoretically, if you placed 4 two terabyte drives into a RAID LEVEL V controller, once they were configured by the firmware, and formatted by the Dish Network software, you would have a total of SIX TERABYTES of usable space for your shared / stored recordings.
FOUR DRIVES at TWO TERABYTES EACH = EIGHT TERABYTES. Subtract the size of ONE drive for checksums, and you have a total of SIX TERABYTES.
Don't worry though, the checksums are not stored on a single drive within the RAID array. OVERSIMPLIFIED: Under RAID LEVEL V, if you store the word CAT, the C is on DRIVE ONE, the A is on DRIVE TWO, the T on DRIVE THREE, and the CHECKSUM on DRIVE FOUR. Again, an oversimplification, but the theory of how RAID ARRAYS, larger than two driver mirroring, work.
The link to the Raid Level V, USB controller, is here: Mediasonic 4 Bay RAID 0/1/5/10 3.5SATA HDD enclosure-usb 2.0 HFR2-S3B#
The advantage of RAID LEVEL V is that if one drive fails, everything will continue to operate, AND, you can replace the defective drive and the RAID ARRAY will rebuild the data on the replaced drive as the system continues to operate.
RAID LEVEL V is generally the best way to go as it gives you the best option to recover data. My work is with highly secure, and scalable, networks which require 100% uptime and availability. Between RAID LEVEL V and remote backup of data - in case of a catastrophic server failure, we are never down.
For the record: I am running Western Digital MYBOOK ESSENTIAL, TWO TERABYTE hard drives on my 722K receivers without a problem. They give us lots of space to store all of the nicely restored, HD versions of everything from Turner Classic Movies and allow us to move them between receivers.
External hard drive storage / transfer is one area in which Dish Network GOT IT RIGHT!
HD Size and how many?
I have searched for a couple of hours (Probably not using the correct search words) and can't find if the 622 now supports more than a 1TB drive?
Wa also wondering what the maximum amount of external drives was for each receiver.
THANKS! :)
BTW, I have a Seagate Free Agent Pro 750GB (sleep disabled) and a 1TB Calvalry drive for my 622 at the moment and they work great!
THANKS! :)
I have 15 EHD's that I swap between 2 622's. My largest is 1.5TB, but I think you can use up to 2TB, now.
DVR percent meter issue
No signal Port 4 External LNB
